Hey I'm switching over to PC gaming at a medium price point. I have had a tough time finding the right gpu. My price for the gpu would be around 200 USD. I have been looking at the 760 and the 270x. Which one is better or is there a better option
Thanks
CPU, 8350 @ 4.3 ghz | CPU COOLER, Hyper 212 EVO | ,MOBO, Gigabyte UD3 AM3+ 990FX | RAM, 8 gb  G.Skill ripjaw 1866mhz | GPUASUS 7970 | CASE, Corsair 230T black and red STORAGE, WD caviar blue 1 TB 7200 rpm | PSU, XFX 750 watt 80+ gold | Keyboard, K70 mx blue (black/red) | Mouse Razer naga hex, | Monitors, Asus VG248QE 24in 1080p, Dell 24in monitor 1080p |
https://linustechtips.com/topic/92596-gpu-for-a-console-replacement/
Thanks
270
Heaven's Society - Like Anime? Check us Out Here!
Thanks
The best you can get is a 270 but do check the 7870XT edition if it's on sale anywhere.
  • CPU i5 3570k - 4.0 Ghz | Motherboard Intel DZ77SL50K | RAM Corsair Vengeance 4GB 1600 BUS DDR3 4GBx1 | GPU 2x Sparkle GTX 570 OC editionCase CM 370 EliteStorage Seagate 1TB 3.5" SATA HARD DRIVE 64MB CACHEPSU Cooler Master GX series 550W (80+ bronze)Display(s) Samsung 46' series 5 TV(1080p), Dell 20' (1280x1024)Cooling 3x Corsair SP120 QUIET EDITION HIGH STATIC PRESSURE 120MM FAN TWIN PACKKeyboard DELL original default keyboardMouse A4 Tech x2 800dpi | Sound On board~!
Uhhhh he was comparing 760 and 270x. The 760 is faster.
That said the 270 (because there is no reason to go for a 270x) is generally quite a bit cheaper
I'm aware of what he said, I said 270 because it's the best option. if you're going to get a 760, get a 680.
Yeah. I know. I agree. Also the 760 and the 680 actually arent that horribly difference in terms of performance. The 680 wins, but not by a massive amount.
You can also grab a 680 cheaper on a good day, and possibly overclock it more. Also aftermarket cooling plates for watercooling should be cheaper for it because it's been around longer? just a guess on that.
Thanks
What 760 did you find for around $200? Lowest I can find is $235.
Anyways, I would grab this http://www.newegg.com/Product/Product.aspx?Item=N82E16814127769&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
One of my friends has a connection and he could get one for cheap, but it would still be around 210.
R9 270 is your best bet, it's a sweet-spot performer at $180, it also consumes very little power & exhausts very little heat, so you can put it in a small enclosure like a bitfenix prodigy without having to worry about heat.
The 680 is closer to the 770 than the 760 in performance.
But yeah, the 760 is more powerful than the 270x.
