I was playing a game and a little boy accidentaly turned my pc off. when i turned it on it shouwed me the error CPU Over Temprature and when i clicked F1 it sent me to Bios. then when i quitted bios the same thing happened again. the third time now my pc  finaly turned on. its not overclocked or anything any ideas?
https://linustechtips.com/topic/925941-cpu-over-temperature-error/
21 hours ago, altertarner said:
how do i check the heatsink? btw the fans in the bios were running
open the case and try to gently wiggle it a bit, it should not move if it moves and is loose you should take it off and reapply paste and re mount the cooler
