im going ot be doing a white build i was wondering what cooler i should get im going to be using the fractal r4 with window so i want it to look good the ones i were looking at were these
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_23&products_id=24047
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_23&products_id=23752
https://linustechtips.com/topic/92521-what-cooler/
https://linustechtips.com/topic/92521-what-cooler/#findComment-1246097
that cooler is way to big
Why? It cools better than the other two and it will fit in the case fine.
https://linustechtips.com/topic/92521-what-cooler/#findComment-1246149
i have the d14 and it is way to big and looks bad performs well but it covers like the whole cpu area and looks really bad
Okay, Silverstone cooler it is.
https://linustechtips.com/topic/92521-what-cooler/#findComment-1246159
Why not spend your money on a pair of glasses instead?  :rolleyes:
CPKoTIx.jpg?1
If you want to downgrade to a 120mm AIO that badly, by all means it's your money.
Error: 410
https://linustechtips.com/topic/92521-what-cooler/#findComment-1246177
looks to big in my opinion
It's never too big  ;)
If you really want a cooler just for the looks, just get whatever you want. Looks are subjective.
https://linustechtips.com/topic/92521-what-cooler/#findComment-1250799
