START UP PROBLEMS - CPU and case fans powered on, but nothing showed up on the display, unless I moved the RAM from one slot on the motherboard to another then computer starts up and runs normally but soon as power down and come back after 10mins and restart same happens again. Any help appreciated.
https://linustechtips.com/topic/925180-start-up-problems/
PC specs ?
if its ryzen i got the same problem (trund out to be the PSU)
"i reject your reality and substitute my own"
          --- Workstion --- GamePc ---
"College great Dropout Engineering"
https://linustechtips.com/topic/925180-start-up-problems/#findComment-11325787
4 minutes ago, THE1RAT said:
Tried another PSU and same thing
Can you try and unplug the pc. so it das not get eny power form the wall and try the same ting you did before
https://linustechtips.com/topic/925180-start-up-problems/#findComment-11325820
What specs? Does your motherboard have LEDs for error codes? What did you do before this issue started?
Can you try running Memtest86 once you get some kind of a display?
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/925180-start-up-problems/#findComment-11325853
