Hello all,
So I recently moved back home from college and any device connected from one just the one AP no longer want to do anything related the internet. Only name resolution problems. I checked the DNS settings on both router and AP and nothing seemed out of the ordinary to me (which doesn't mean much).
$ ping google.com
returns
ping: goolge.com: Temporary failure in name resolution
So, I changed /etc/resolv.conf to 8.8.8.8 at first with no results. I also tried with 1.1.1.1 and no cookie.
Similarly,
$ dig google.com
returns
; <<>> DiG 9.10.3-P4-Raspbian <<>> google.com
;; global options: +cmd
;; connection timed out; no servers could be reached
This is about where my knowledge ends on this subject, so all help is greatly appreciated.
Thanks in Advance
EDIT:
The only two things attached to the AP are my gaming rig and a RaspberryPi (Debian based). The "AP" is just a ASUS RT-N66R running in AP mode.
https://linustechtips.com/topic/924988-problems-with-ap-name-resolution/
25 minutes ago, brwainer said:
Can you ping things by IP address, e.g. “ping 8.8.8.8”
No, but I can still ssh from other points on the network (if that matters)
$ ping 8.8.8.8
From [IP] icmp_seq=1 Destination Host Unreachable
Edit: took out the IP b/c I'm not sure if it was just the local IP or not
5 hours ago, andrew2165 said:
Hello all,
$ ping google.com
returns
Similarly,
$ dig google.com
returns
Thanks in Advance
EDIT:
Do a trace route and reply
$ ping 8.8.8.8
Can you ping your router’s IP? Also, was the IP you redacted your computer’s own IP, or did it differ?
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
$ traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 60 byte packets
 1  raspberrypi ([local IP])  1239.208 ms !H  1239.144 ms !H  1239.051 ms !H
$ traceroute google.com
google.com: Temporary failure in name resolution
Cannot handle "host" cmdline arg `google.com' on position 1 (argc 1)
Yes, I can. And looking back at it, the IP was just the static IP of the computer.
Is your router’s IP set up as the default gateway of the computer? And can you show us your routing table? (“ip route show” on most linux systems)
EDIT: any private IP (starting in 10. , 172. , or 192.168. ) are safe to show publically. They can’t be abused in any way.
It doesn't appear to be the default gateway
$ ip route show
default via 10.88.52.251 dev eth0 src 192.168.1.20 metric 202
10.88.52.251 dev eth0 proto kernel scope link src 192.168.1.20 metric 202
192.168.1.0/24 dev eth0 proto kernel scope link src 192.168.1.20 metric 202
So I googled how to change it
$ ip route | grep default
# 10.88.52.251 is not the router's IP
$ sudo route add default gw 192.168.1.1 eth0
default via 192.168.1.1 dev eth0
$ ping google.com
ping: google.com: Temporary failure in name resolution
Also, thanks for the IP clarification. I wasn't 100% sure and didn't want to risk it
$ ip route show
$ ping google.com
You need to remove the other default gateway also.
