So doe's ring ratio affect the performance of the PC that much? Do i need an exact one to one ratio if im trying to get it one to one and if i am and its not stable do i increase the ring voltage or the cpu voltage?
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/92491-ring-ratio-huh/
Whats the ring ratio?
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/92491-ring-ratio-huh/#findComment-1245949
wat
No really. Normally I try to post constructively, but .... wat
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/92491-ring-ratio-huh/#findComment-1245979
wat
Ring bus jog any memory's, idk, its new to Haswell, i can't even find anything about it but Linus mentions it in his Haswell OC Guide.
| F@H STATS |
https://linustechtips.com/topic/92491-ring-ratio-huh/#findComment-1246025
The ring bus is just part of the theory on how that architecture operates, it's not a "feature" or "spec".  Don't worry about it.
Thanks
| F@H STATS |
https://linustechtips.com/topic/92491-ring-ratio-huh/#findComment-1246193
If you mean the Cache? Yes it helps. Raising VCCIN, rinbgus also increases temps. Ring bus people usually run around .10 lower then their vcore when dialing in their chips.  VCCIN is different on every chip. Some need 1.9 to even do 3900 cache and a stable oc on the clock as well. My friend needed 1.9 VCCIN on the same board and I needed 1.776. Haswell's have huge swings EVERYWHERE.
Clock>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Memory>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Cache
4.5/4.0 will kick the crap out of 4.3/4.3
If you can clock the cache higher and still keep temps down on the max clock of the chip? Do it. If not? Who cares. 3900 4000 cache is plenty, especially on air.  My cinebench scores stomp on 1:1's with higher clock rates from oc'ing my memory to 2133 from 1600. I saw way more performance in benchmarks OC'ing memory then I did trying to get 1:1 cache or 100mhz cache or "within 300" crap. I actually saw about a 1.5 fps increase in a cpu bound game (Guild Wars 2) with a memory oc as well.
I have no idea where people came up with this 1:1, within 300mhz garbage (prob the same people who say adaptive voltage is awesome on air and say stress test with it, and 1.4-1.5 volts is good to go, and 90C temps are ok) but it sure doesn't hold to form in benchmarks or actual performance. No I am not saying you have to OC memory. I am saying that clock is everything. Memory is "ok" in benchmarks. Cache is nothing special.
To test the cache OC use aida 64 and just click cache. Other ways of testing are way too lengthy and you will go crazy trying to dial it in over days. Crashing on cache 9 hours in? Just sucks. Many people just set cache to 3500 when dialing in a clock, because otherwise it makes stability testing a nightmare.
You might also find (and every chip is different) that by just raising V core and getting higher core clocks, you can run higher cache. For me at 1.150 V @ 4.3 I could only run 3900 cache. With just 1.776 VCCIN and 1.22 cpu voltage @ 4.5? I could raise my cache to 4000.
If your motherboard set it to 3900 (auto) and you don't want to mess with it? That is fine to. Cache is a gigantic pain in the butt, and offers the least performance of all the OC's.
If all this wasn't confusing enough? You have this as well. You want your VCCIN to be within a certain range of your CPU voltage. If you aren't in that range? You can harm the chip. So these people advising "just go to 1.9 vccin blah blah"? Are wrong.
http://rog.asus.com/244672013/labels/featured/introduction-to-fully-integrated-voltage-regulators-fivr-on-maximus-vi/
So attempting 1:1 and setting some voltages to high in relation to other voltages? Can F your chip up.
CPU:24/7-4770k @ 4.5ghz/4.0 cache @ 1.22V override, 1.776 VCCIN. MB: Z87-G41 PC Mate. Cooling: Hyper 212 evo push/pull. Ram: Gskill Ares 1600 CL9 @ 2133 1.56v 10-12-10-31-T1 150 TRFC. Case: HAF 912 stock fans (no LED crap). HD: Seagate Barracuda 1 TB. Display: Dell S2340M IPS. GPU: Sapphire Tri-x R9 290. PSU:CX600M OS: Win 7 64 bit/Mac OS X Mavericks, dual boot Hackintosh.
https://linustechtips.com/topic/92491-ring-ratio-huh/#findComment-1246504
