Seems like you are on a laptop. Set your windows power plan to high or Maximum performance. This should help turbo up the CPU.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/924117-cpu-is-at-low-speed/#findComment-11315078
3 minutes ago, keny said:
it was max to begin with
then usually the other reason it will be so low is thermals. Go download something like Coretemp or realtemp and see what your CPU temps are at. It will throttle down when temps get to warm to protect itself.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/924117-cpu-is-at-low-speed/#findComment-11315090
