I just recently built a computer for my friend. Specs are:-
Ryzen 2400G
MSI B3350M- PRO VDH
8GB kingston hyperx memory 2400Mhz
and the problem is that I am getting very low performance from the processor. On medium settings I hardly get 40fps in rocket league and similar is the case in games like these. I have seen that people are getting way above 50 fps with very high quality settings and I am getting half of it on half the settings. I have tried to re-install AMD driver several times but it didn't help and I tried to increase the VRAM in Bios, but its locked there. Don't know whats wrong.
https://linustechtips.com/topic/924111-ryzen-2400g-performance-issue/
I guess you are running integrated gpu?
Pls run a standardized Benchmark with standardized settings like Unigine Valley, Firestrike and such. Game Settings can vary quite a lot sometimes.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
I am running heaven benchmark and what I am seeing in the task manager is that CPU usage is very low like 1-5% only whereas GPU usage is easily going around 70%.
Gpu should be at 100%.
What results do you get? And what exactly are your settings? Pls post the end result here.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
7 hours ago, Some Random Member said:
Is windows in high performance mode, or power saver?
Don't know.
Just checked. It's on balanced mode.
I am running at 1080p, medium settings with 2x AA in heaven. I am getting like 10-15 fps
Sooo, have you re-run the test on high performance?
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
3 minutes ago, sarfraz said:
Yes. Same result.
Okay dude, you give so little information that I don't think that you actually want help. Good luck.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
