Hi guys. I'm doing my first build, and I've already ordered (most arrived) all the components listed below except for the case, power supply, storage, and ram. Reason for that is because when I was doing my research people are talking about how AMD rams are like different in some ways, and M.2 drive stealing bandwidth and stuff. So yeah, please, if you are so kind, go through my list and check if there are any incompatibility issues. Also is 1000w enough for overclocking/ if i am to add a custom loop in the future? Also are some components in this list bottleneck/overkill for others?
Thanks A LOT in advance !!!! thanks thanks thanks thanks thanksdfe
https://pcpartpicker.com/user/Ch1ya/saved/ZVRccf
AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor
Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler
Asus - ROG Crosshair VII Hero (Wi-Fi) ATX AM4 Motherboard
G.Skill - Trident Z RGB 32GB (4 x 8GB) DDR4-3200 Memory
Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING Video Card (2-Way SLI)
NZXT - H700i ATX Mid Tower Case
Corsair - RMx 1000W 80+ Gold Certified Fully-Modular ATX Power Supply
Microsoft - Windows 10 Pro OEM 64-bit
https://linustechtips.com/topic/924073-ryzen-build/
1000w is overkill, a 750-850w psu is enough if you're gonna do SLI.
https://linustechtips.com/topic/924073-ryzen-build/#findComment-11314607
Yea, I'm running a R7 1700 overclocked to 3.9GHz, 4x 120mm and 1 90mm fan, an AIO pump, GTX 1070, 1 SSD, 1 M.2 NVMe drive, 16GB of RAM (overclocked), 2 12" RGB strips in case, RGB Gaming Keyboard, RGB Gaming Mouse, Blue Snowball USB condenser Mic and I am pulling a tad over 400W from the wall under load with a 650W PSU. Stuff is so much more power efficient these days you don't need massive overkill PSUs for Gaming Rigs anymore.
https://linustechtips.com/topic/924073-ryzen-build/#findComment-11314620
35 minutes ago, Ch1ya said:
Why would you ask after you ordered everything?
Could have gotten a more reasonable motherboard.
otherwise I hope you're gaming at 4k 60hz or 1440p 144hz.
https://linustechtips.com/topic/924073-ryzen-build/#findComment-11314642
I see. will do
https://linustechtips.com/topic/924073-ryzen-build/#findComment-11314647
meanie..
I was concerned about the comparability of motherb/ram and motherb/storage...
https://linustechtips.com/topic/924073-ryzen-build/#findComment-11314649
3 minutes ago, Ch1ya said:
meanie..
But you already bought it? So you couldn't easily change/fix anything if there was a problem.
https://linustechtips.com/topic/924073-ryzen-build/#findComment-11314654
He has probably done a better by a 1000w unit as his current power draw is around 749w(calculated by pcpp?)..
Also.... dont u see that that PC has dual 1080ti's and a 2700x
https://linustechtips.com/topic/924073-ryzen-build/#findComment-11314747
That calculator isn't reliable at all. Under a gaming load it's probably closer to 600W
https://linustechtips.com/topic/924073-ryzen-build/#findComment-11314752
ASUS GTX 1080 Ti Strix OC SLI Review
650w with Strix 1080tis on a 6850k, and this is just from the wall. a good 750-850w psu is more than enough.
https://linustechtips.com/topic/924073-ryzen-build/#findComment-11314757
