so some days ago my pc has started to freeze all of a suden, So yesterday I decided to format my pc because I thought it was a virus that my antivirus did not catch. So after 3hours of formatting my pc is "New" y start using it for 2hrs and all of a sudden it freezes again. I would like to know if this is because of windows new update or what. Thanks Tomigames123
Pc Specs:
i7-7gen
16ram DDR4
1060gtx 3gb
1T of HHD Storage
111gb of SSD Storage (windows is installed here)
https://linustechtips.com/topic/924054-help-cpu-i-think/
-Moved to Troubleshooting-
Are your drivers all up to date?
https://linustechtips.com/topic/924054-help-cpu-i-think/#findComment-11314432
1 minute ago, Tomigames123 said:
if am not mistaken yes. I run every test and it says its good and it "fixed" a power issue.
Quote me if you want me to see your reply quickly :)
Have you tried reinstalling Windows?
https://linustechtips.com/topic/924054-help-cpu-i-think/#findComment-11314449
yes I did it 2 times that was the reset
I don't mean reset, I mean reinstall.
Wipe the drive and start over.
https://linustechtips.com/topic/924054-help-cpu-i-think/#findComment-11314457
