I have a Dell Inspiron gaming laptop which has an I7-7700HQ and a GTX 1050ti graphics card however while playing Rainbow Six Siege, GTA 5 and many other games i have found that the GPU is only using around 40% of its power but im not getting 60 FPS. My CPU is only using around 40% too with around 8GB of the 16GB of ram being used too. I am not being limited by temperature either as temps maxed out at just 62 degrees Celsius. What can i do??image.png.68d9c8af144027b43889eb46fa04068d.pngimage.thumb.png.bb52b46eec8ec860bac43008e47fdd6d.png
Check if power saving mode is turned on in windows 10
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
Frame caps in game settings or utilities?
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
Check CPU clocks while gaming.  I had this problem on an i5-7300 HQ/GTX 1050 Ti laptop (6 months old), the CPU was throttling hard.  Replaced thermal paste and the CPU throttling went away.
Also, make sure you are not running a low refresh rate with v-sync on.  Some laptops will default to 20-40hz for battery savings with no obvious way to change it to 60hz.  Under display settings click on display adapter settings and set the refresh rate manually to the max that the display supports..
5 hours ago, A1Mike_W said:
I can't find the specs for your screen anywhere but if by chance your display is 90hz and you're got half-rate adaptive vsync on then you'll be capped at 45fps. It's unlikely but worth a shot.
this
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
For some reason my FPS has increased again closer to 60 however it is fluctuating a lot its not locked at 60 as it once was. I've also set MSI afterburner to monitor CPU usage, temperature and clock speed. Clock speed is constantly at 3610 Mhz, usage is around 60-70% but my temperature is fluctuating massively too as if its the usage. It was at 68 degrees then jumped to 75, dropped back to 71, jumped to 77 and kept fluctuating between 70 and 80 degrees. this is not over time but is changing each second. My GPU temperature is constantly at around 54 in gameimage.thumb.png.694f982c5023f8497ba0b4b88d798502.pngimage.thumb.png.c617f9f9f15400fb041ce27f2ca96e0c.png
Sounds very similar to the issue I had.
My laptop was taken with me every day and the vibration/shock of being carried around impacted the performance of the stock TIM.  I used a more liquid compound when I applied new paste and have not had an issue since.
