Radiator Placement question
Solved by iRileyx,
Loop order doesn't matter.
Go for whatever order is easier for you to install, or whatever you think looks nicest. As for having a quad/double vs just a quad, most gpu and cpu combo's will be fine with just a quad.
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab3 -
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0
play_circle_filled
Latest From ShortCircuit:
