Hi,
I'm looking at building a new PC soon with most likely a Ryzen 2700. In my current PC I have a Corsair H60, and I'm thinking about using it for the new PC build. I know I need to buy the AM4 mount. But my concern or question is that I build this PC in 2013. Should I be concerned with putting the H60 which is 5-ish years old into my new build? I haven't had any issues with my H60, so I assume its fine and shouldn't leak. I know the wraith spire should be fine, but then I just have a H60 sitting around so like why not use it.
Been her for a while but never posted a thread before so please be kind.
https://linustechtips.com/topic/923344-reusing-corsair-aio/
It should be fine but you can fall back to the stock cooler if it fails.
https://linustechtips.com/topic/923344-reusing-corsair-aio/#findComment-11307611
Greetings,
I don't see why there would be an issue with the H60. AIOs are not as prone to leaking as a custom water cooling solution, so it should be find when you move it.
Overall, I think you will see better temperatures with the AIO than the included cooler.
One thing you may want to replace is the fan on the H60. After 5 years, the bearings could be starting to go bad.
And if it doesn't work well for you, then just switch the coolers out.
Good luck
https://linustechtips.com/topic/923344-reusing-corsair-aio/#findComment-11307618
27 minutes ago, azkite said:
my biggest concern was just if it leaked, just cause that would suck after getting new parts.
About 2 years ago I replaced the fans with corsair SP120, they look and sound fine. I clean it out every 2 months.
Failure is more likely to occur from a failed pump than leaking on an old AIO.
https://linustechtips.com/topic/923344-reusing-corsair-aio/#findComment-11307685
