8700K 4.9 @1.28v
z370 Taichi
Windows 10 v1803
Changing the minimum (and even maximum) processor state in the high performance power plan makes no difference, even after a restart. The CPU remains at max voltage and 4.9GHz regardless. Fairly sure this is a Windows bug rather than a BIOS setting because the balanced power plan allows the CPU to downclock.
Any ideas for a fix?
if you disabled power states in bios, C1, C3,C6, EIST windows cannot control cpu clocks.
My opening post is three sentences long and you couldn't even read it all properly. Thanks.
