hello,can you tell me if I can overclock Intel pentium e5300 with this build:
x2 1GB 800Mhz DDR2
420W PSU
motherboard:G31-M7-TE
case fan: Martech DF080251SEMN 80nmx22mm
GPU: NVIDIA GT 520
160 gb + 500 gb hdd(7200rpm)
i removed optical drive
if I can OC it,what CPU speed would you recommend?I don't know anything about OCing,help please
idk if a 420 PSU can handle overclocking a e5300 dual core processor
https://linustechtips.com/topic/923069-help-me-with-ocing/
G31 chipset is really bad for overclocking
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/923069-help-me-with-ocing/#findComment-11305127
Performance still isnt there with overclocking. Besides, I doubt if you have the cooling for it.
Desktop benching:
https://linustechtips.com/topic/923069-help-me-with-ocing/#findComment-11305131
