Dead drive?
Go to solution Solved by Radium_Angel,
9 minutes ago, Holabubu said:
anyway i can restore whatever i had in it to a new drive ?
I used to do data recovery professionally for many years.
Unless the data is not critcal, you'll need to send the drive to a data recovery specialist.
If you don't care about the data (aka, you have a backup) then PM me, I'll give you some tricks
If you have backups then you can just restore them to a new drive. If you do not have back up and cannot get data off the drive you will most likely need to get a data recovery service to get your data off if its important enough to warrent the cost of it
Maybe something's cool down here?
System specs are in profile
Just an average guy looking around the forums for something intresting...
Enjoy your memes. ^_^
https://linustechtips.com/topic/922500-dead-drive/#findComment-11299593
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/922500-dead-drive/#findComment-11299620
