Two Issue sandwich.
Drive issue solved, kind of.
I apologize if this gets a smig rambly as I wish to provide a fuller picture at least on this one part.
I post this for anyone else hunting in these forums for the 3TB+ drive not being fully seen issue.
If you have data on the drive, I'm sorry but this won't be the fix you're hoping for.
To outline again my own issue.
- I took a external drive that used to have a windows 7 OS system made backup, out of its enclosure because I couldn't find its stupid proprietary USB cable.
- Putting the drive directly into my PC, it was not seen even after a reboot and a full power cycle. I don't know why.
- It -was- detected via a Sata/USB adaptor I borrowed from my father.
- While already being seen as a GPT drive, it had no drive letter assigned and only showed one 746GB unallocated volume through Drive Manager, and another small 128MB volume via Aomei Partition Assistant.. [some random freeware I found in conjunction with their backup tool when I googled top 10 backup tools because I didn't want to deal with Window's built in one again.]
Now anything I Googled said stuff about updating Intel Rapid Storage Technology driver/program.. mine wouldn't update despite using versions that listed the C600 controller chip my board has, if that includes you then those are versions 14.8 and older.
That said I did realize my version was one different, RTS Enterprise, and two 32bit.
I believe, perhaps, the installers of the non Enterprise versions where trying to load the 64bit due to 64bit OS..
I've not tried installing the Enterprise version as it mentioned requiring a F6 driver install method and it so happens I don't have any USB keys laying around like I used to back in College, and the wording of ReadMe.txt on the process made this sound like something only doable during a OS install.
I decided I had nothing really left to lose with the drive, I was intending to wipe it anyway to backup my current Win 10pro (1703) system.
I created a new volume with the 746GB volume & a NTFS format.
After this, remembering somethings I'd seen on the forums about Intel RTS; I reconnected the drive to directly to my PC's mobo (yay hotswap bays), and rebooted.
The drive was seen and a 2TB unallocated volume showed up.
Using Drive Manager I deleted the fresh volume I had just made allowing the full 3TB to unallocated then formated the whole thing into a NTFS Volume.
I hope this helps anyone else with this issue, I'm sorry I don't have a fix that retains retrievable data on the drive.
~Umi
