9 minutes ago, Raphccast said:
anytime i play a game a buzzing sound comes out my headphones but im not sure if its a coil whine because i do not hear it when i have no headphones plugged in, please help
CALM DOWN!!
lol just kidding, whats probably happening is that there is something loose in your headphones. That is causing some sort of electrical interference. (which makes noise)
https://linustechtips.com/topic/921313-help/#findComment-11287656
14 minutes ago, coyotetracker said:
CALM DOWN!!
tried the second one and it just made it louder
https://linustechtips.com/topic/921313-help/#findComment-11287701
1 hour ago, Raphccast said:
theyre just normal apple earphones (im not much of a headset guy) I tried switching them a different type but the noise is still there
You've tested the headphones on other equipment, and tested multiple headphones on your computer, so that's ruled it out to definitely being grounding in the PC This could be a bad motherboard chipset, or simply that the board is not making proper grounding with the mounting screws or your case. I would start checking to see if this is the case, and even go as far as removing the motherboard and components from your case to put them on cardboard and test things outside of the case. If you still get buzz, then it's a motherboard audio chipset issue, otherwise it's your case.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/921313-help/#findComment-11287857
The following 2016 blog entry helped the deal with the buzz...
https://linustechtips.com/topic/921313-help/#findComment-11291007
