looks good enough than mine haha while I am only using an matx board.. i also am using a matx case and if you think your cable management is bad, you should see how much smaller of a space there is in an matx case xD
well you can just add another fan up top as exhaust... I also like the white theme you have going with your fans
https://linustechtips.com/topic/921136-my-first-pc/#findComment-11285939
Thanks xD my theme is White and Yellow for Lights
https://linustechtips.com/topic/921136-my-first-pc/#findComment-11286150
