Success!
So I was getting idle temps around 70C and it topped 105C when I entered a game (Planetside 2) before I exited.
I was sure something fishy was going on. I tried to mine some coins and the temps went off the chart; I think it was then when the stock compound gave way. After watching a tutorial from Tek Syndicate (RazetheW0rld), I decided to disassemble my card and reapply thermal compound.
The stuff I have is Tunis's MX-2, so it's conductive... But I obviously risked it. Now I'm getting 45C idle.
Another computer task checked off the list.
ps... The card is an OEM AMD 6770, if you couldn't infer from my 'sig.
Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ
https://linustechtips.com/topic/92050-thermal-compound-replacement/
What is your case? Is the card impeded a air flow path? Try leaving the PCI brackets below the GPU open, that will give a place for hot air to flow out. That can improve temperatures a lot in some cases.
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
