Cpu Heat
Go to solution Solved by Yakusoku,
I had it with two fans blowing into the rad and pulling out from the other side. Seems the one pulling died or isn't working as well anymore, removed it and moved the working fan to pull out air from the rad replacing the dead fan.
Back to nice 50C on idle despite only have one fan on it ;D
3 years and still going strong! H60 Corsair really doing me well over the years.
Just noticed it booting up the system today.
Its hitting 70C with nothing running. (Task Manager doesn't seem to show any suspicious activity) It spikes to 85-99 with just Firefox on.
This is surely not normal. Is my AIO dying or is there something else that's causing this.
Thanks!
https://linustechtips.com/topic/920483-cpu-heat/
Maybe your AIO pump is dead.
Also check if your AIO is even making contact with the CPU IHS.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/920483-cpu-heat/#findComment-11279886
https://linustechtips.com/topic/920483-cpu-heat/#findComment-11279977
I would not consider 50C a nice idle temp considering i hit a max of 60C under load (i7 4790k). Seems normal for a H60 though, i had one for 3 years aswell, wasn`t too happy. Gaming temps spiked into the 80`s. Much happier with the Mugen 5 now.
Main Rig:
CPU: i7 4790k -> Scythe Mugen 5 (Dual Arctic P12)
MoBo: Asus Z97 Pro Gamer
RAM: 32GB DDR3 1866MHz Crucial Ballistix Sport
GPU: EVGA GTX 1080 Gaming -> Arctic Accelero Twin Turbo ii
PSU: Bequiet Pure Power 10 700W
Case: Bequiet Pure Base 600
Mobile Gaming 1: (XMG Fusion 15)
CPU: i7 9750H
RAM: 32GB DDR4 2666MHz
GPU: RTX 2070 MAX-Q
Mobile Gaming 2: (XMG P502 Pro)
CPU: i7 3740QM
RAM: 16GB DDR3 1600MHz
GPU: GTX 675MX 4GB
Ultrabook: (Dell Inspiron 13 5378)
CPU: i5 7200U
RAM: 16GB DDR4 2133MHz
GPU: HD 620
Server:
CPU: Athlon II x4 630
MoBo: Gigabyte/Dell 4GJJT
RAM: 4GB DDR3 1066MHz
GPU: Radeon HD 5450 1GB
https://linustechtips.com/topic/920483-cpu-heat/#findComment-11280436
