The only option i could find would be Swiftechs MCW60 which is a GPU only waterblock; however, these have long been discontinued so are pretty hard to find. Not sure if anyone else can find anything - ebay might be worth a look. Sorry :/
https://linustechtips.com/topic/9204-graphics-cards-water-block/#findComment-101367
Yes, problem with older cards is no one makes gear for them anymore. You be better off upgrading those cards to something newer that you can watercool, and selling them on Ebay.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/9204-graphics-cards-water-block/#findComment-101372
