8 minutes ago, Zig-Zag-OCN said:
I have a FX8350 @ 4.2 Asrock 990FX Extreme 3 16gb crucial ballistix sport ddr3 1600 SLi GTX260 216's < yea i know. And a  WD 10k rpm. On all low settings. As low as they can go I get around 15 fps average. What can be done with what i have?
Your only option is to upgrade. You’d have trouble playing Minecraft on that lol.
https://linustechtips.com/topic/920138-arma-3-help/#findComment-11276741
Is this in Single player or multiplayer?
An under powered MP host server can tank your FPS
Your PC is definitely on the minimum required to run side and should be upgraded for Arma but that might not be an option.
Make sure you aren't running any mods
Make sure you not running anything unnecessary in the background
Start at 720P
All setting low
No AA
No PIP
View Distance to minimum
Test on an empty map in the editor and see what FPS you get
if it's better slowly up your settings and test again
Also try disabling SLI and see if that makes a difference. SLI was very buggy for me in Arma 3 so I went back to single card.
You could also try the CUP Terrain mod and play on the old Arma 1 or 2 maps as those usually give much higher fps
https://linustechtips.com/topic/920138-arma-3-help/#findComment-11280142
1 hour ago, ImNotDeViLzzz said:
Arma games are known to be totally unoptimized.  The engine for the games is terrible.  Poor performance is common for many no matter the hardware.
Yea I know iv been a arma player from ArmA lol. And yes it is that bad in SP with everything as low as it can go @ 1366x768.
https://linustechtips.com/topic/920138-arma-3-help/#findComment-11280575
7 minutes ago, Zig-Zag-OCN said:
Cold War assault is the only one i don't own lol.
Cold War assault doesn’t have stamina. It’s imo the best because you only get like 2 guns to choose from. It boils everything down to only what’s needed in a Milsim. Also your character doesn’t have asthma.
Ps quote me to get replies.
edit:
dont turn your graphics to max on it or it’ll never work again.
https://linustechtips.com/topic/920138-arma-3-help/#findComment-11285301
8 hours ago, Zig-Zag-OCN said:
Well last night was a bad one i lost both of the 260's. Had a dead gtx 650 that got the oven treatment and it's back lol. Soooo now would it be worth it to go with 2 gtx 550ti's in sli?
If you already have the cards then it can't hurt at this point. I'd try one fist and see how it likes that and then add the 2nd and try SLI.
If not, keep your eyes out for a deal on a used 750 ti, 760, or 950. all should be found under $100 if you need to be budget conscious and be at least as good if not better then SLIing those cards.
A new PC with a Ryzen or intel cpu and current mid range GPU would still be a better bet if it's in the cards. Arma does love a faster CPU
https://linustechtips.com/topic/920138-arma-3-help/#findComment-11286080
Yea I was looking at 2 550's for like $50 for both shipped. And i run my 8350 at 4.5 24/7 but I needs a better cooler. I wish i had the $800 for a new build!
https://linustechtips.com/topic/920138-arma-3-help/#findComment-11288484
If you have to buy cards, I would look at a used 750ti at the very least if not a used 950.
https://linustechtips.com/topic/920138-arma-3-help/#findComment-11295633
