hi, so i purchased a fan system which is forced to always stay on , it sits under my gpu, it has a switch on the back to go from low to high, its super noisy at low,
my gpu runs at 130F (gigabyte geforce GTX 1050) when not gaming, by turnign this on its now at 102F non gaming, pretty huge improvement since my case has insane airflow, because its so noisy i dont want it on all the time, can someone link me to a ide power (molex i think its called) switch piece which i can controll via a wireless remote through the plastic window on my case? Thanks in advance :)
If my Response helped you, Please click the Check under my reply, to mark it as The Solution!
https://linustechtips.com/topic/920106-ide4-pin-power-wireless-switch/
