I don't see why any standard mATX or larger case wouldn't work.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/919909-i-need-help/#findComment-11274564
33 minutes ago, Onlyhate said:
100% do not buy an A320 motherboard
 the Minimum motherboard you want for AM4 is the ASrock Pro 4
But what's your full hardware list?
If you need a micro ATX case buy the Q300L most likely, pretty neat, the L is the one that actually has airflow, it's like $40
https://linustechtips.com/topic/919909-i-need-help/#findComment-11274579
Any case larger than mATX will work, so most standard midtower ATX cases will work, but it may look a bit awkward. This will hopefully give you a good idea of how different form factors look next to each other.
Ryzen 7 2700X  ASUS X470 PRO  16GB 2400Mhz Crucial Ballistix SAPPHIRE RX 580  970 EVO  Dark Rock PRO 4  Dark Base PRO 900
https://linustechtips.com/topic/919909-i-need-help/#findComment-11274587
