-Moved to Troubleshooting-
Why not just set up a Windows Homegroup and add both computers?
https://linustechtips.com/topic/918324-lan-network/#findComment-11259310
HomeGroup indeed.
Second thing to check would be sharing settings.
Third option could be firewall.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/918324-lan-network/#findComment-11259326
Does it have to be via a wire? Otherwise you could use something like Samba to transfer files and things.
https://linustechtips.com/topic/918324-lan-network/#findComment-11259372
@shahab99110 Check that your firewall is setup correctly (check both computers)
Open the RUN prompt (hold the Windows key + R on your keyboard)
type ;
wf.msc
Check the Inbound Rules and Outbound Rules, make sure that the “File and Printer Sharing” rules are set to “Allowed” and that they are enabled.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/918324-lan-network/#findComment-11259412
