Hey again
Thanks to @Princess Cadence I have found the perfect cpu for my nephew and we've picked all the other parts together . This pc will be used for mostly cpu taxing games like factorio and rimworld and maybe some AAA games , I have chosen intel beacause of 2 reasons
1.No need for overclocking and great IPC
2.Igpu as a redundancy in case linux encounters any issues with his 1060.
The board may not be the best value but we'll it's his build and I'd rather he had a kickass rgb board rather than a value one and be dissatisfied with it.
Here is my build
https://pcpartpicker.com/list/pgXcq4
Is it good?
https://linustechtips.com/topic/918312-my-nephews-first-pc/
the macho is quite overkill for a locked i5, use the stock cooler. get an aidos black for $10 if it ends up not being enough. no reason to get such an expensive board unless you absolutely need the extra features, just cget a cheap H310/B360 board.
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259233
4 minutes ago, CaseyCracey said:
Hey again
Here is my build
Is it good?
Is he gaming on it?
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259234
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($178.89 @ OutletPC)
Motherboard: Gigabyte - B360M DS3H Micro ATX LGA1151 Motherboard  ($67.66 @ Amazon)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($159.99 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($74.89 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: EVGA - GeForce GTX 1070 Ti 8GB FTW ULTRA SILENT GAMING Video Card  ($549.99 @ Amazon)
Case: Fractal Design - Meshify C Mini Dark TG MicroATX Mini Tower Case  ($85.64 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($53.98 @ Newegg)
Total: $1230.83
Generated by PCPartPicker 2018-04-19 11:49 EDT-0400
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259256
This ^
I would go with the Hyper 212X which is what I got for my i7 8700, it is drop dead silent and great value ^^
Indeed for a locked processor we don't need to go all in with the motherboard, I would personally advise this one instead:
https://www.asus.com/Motherboards/ROG-STRIX-B360-G-GAMING/
As it is cheaper but still looks awesome, and being micro-ATX you could use this case instead:
http://www.coolermaster.com/case/mini-tower/mastercase-pro-3/
This way you're getting a more compact feeling build still retaining awesome aesthetics, great air flows and all for a bit cheaper.
Also since this is a locked motherboard (only z370 is unlocked) you can not overclock the memory meaning any thing with a higher frequency than 2666mhz is rather pointless, you could save some money looking for a 2400/2666 kit instead.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259258
3 minutes ago, CaseyCracey said:
Hey again
Here is my build
Is it good?
The fastest speed ram you can run on that is 2666MHz. So depending on price then go with a lower speed kit. The 3200MHz will work though, but at 2666MHz.
Maybe save a bit on the SSD. A Team Group L5 would do fine for a 1st pc, or a Crucial MX500. No real need to get it in M.2 format either unless it is cheaper. Just go with a regular SATA version.
As mentioned above, the cooler is a bit of a mismatch. A cheap $20 would be fine. Maybe something like a Cryorig M9i.
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259260
don't really like the 212s TBH, gets matched in performance by a cooler less than half it's price.
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259279
My main complain would be the mounting mechanism, it certainly isn't the best ever but over all it will outperform the stock cooling by a mile and the last X revision fan really is as quiet as it could get...
Though other options like the Gammax 300 and so on certainly are very viable, any thing but stock cooler if any thing... damn I still have nightmares from its noise back in my i7 6700 days with one.
Personal Desktop":
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259306
I would suggest a slightly different configuration. It is ~US$45 above the OP system. It could be brought under the OP build by switching the 1TB ssd for a 500GB ssd.
I'm suggesting a higher clocked cpu. Still a 65W TDP part so it doesn't need aggressive cooling.
One could use the stock cooler. I've opted for the very decent Cryorig H7 which will do a better, read quieter job.
Since the cpu is locked, I swapped out the DDR4-3200 memory for DDR4-2666. It's a little less expensive and has Aura Sync compatible RGB lighting.
The most significant change was to swap out the small ssd and large hdd in favor of a 1TB ssd. Greatly simplifies the storage layout and offers excellent storage performance for all programs.
No need for a 550W 80+ Gold cpu. The CX450M is a very good 80+ Bronze. There is more than enough capacity to handle upgrades.
CPU: Intel - Core i5-8600 3.1GHz 6-Core Processor  ($224.00 @ Amazon)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.89 @ OutletPC)
Motherboard: Asus - ROG Strix H370-F Gaming ATX LGA1151 Motherboard  ($138.99 @ Newegg)
Memory: GeIL - SUPER LUCE RGB 16GB (2 x 8GB) DDR4-2666 Memory  ($172.99 @ Newegg)
Storage: Western Digital - Blue 1TB 2.5" Solid State Drive  ($229.99 @ Amazon)
Video Card: Zotac - GeForce GTX 1060 6GB 6GB AMP! Edition Video Card  ($339.99 @ Amazon)
Case: Rosewill - CULLINAN ATX Mid Tower Case  ($99.64 @ Amazon)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($47.00 @ Amazon)
Total: $1287.49
Generated by PCPartPicker 2018-04-19 11:56 EDT-0400
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259316
oh yeah the mounts suck big time, my TPC812 uses the same mounting and it won't stop twisting all the time xD
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259321
Sorry just one more question guys , I saw Linus review the Hades Canyon and that thing is bananas like it blew my mind , I've been using an Xbone for a while and that thing is like awesome . It will be 100 USD over budget though . I know it's worse value and not upgradable but would it run games at 1080p60 for the next 2 years?
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259329
it should be fine for that, but keep in mind that you get zero upgradibility with the NUC.
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259334
I know man but dear it's amazing , like the size the IO , when I showed this to my nephew he really likes it so maybe?Like I'd likely pay a price premium due to the tech inside but it's awesome . Like  my mind is blown .
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259340
unless being tiny is a necessity, I'd just skip it for a regular rig.
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259365
2 hours ago, CaseyCracey said:
Hey again
Here is my build
Is it good?
8400 + 1080
THIS SHOULD BE A WAY BETTER BUILD
Motherboard: ASRock - B360M Pro4 Micro ATX LGA1151 Motherboard  ($88.19 @ Newegg)
Storage: SanDisk - SSD PLUS 240GB 2.5" Solid State Drive  ($69.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB D5X Video Card  ($604.98 @ Newegg)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  ($38.99 @ SuperBiiz)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($34.33 @ Newegg)
Total: $1235.05
Generated by PCPartPicker 2018-04-19 14:37 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/918312-my-nephews-first-pc/#findComment-11259896
