Beogram 1000 issues , help.
Solved by Volbet,
1 hour ago, Ridska said:Nope , its not an oscillator, its a metric PSU with a dial that can pump upto 250 V AC , the max amp that it can pump is 3A.
And there is nothing wrong with the belt , the problem is that there is no slippage, The table is turning a bit faster and slowing back down to 33 rpm.
If there was slippage, The table would have been going much slower than 33 rpm.
It was not so much slippage I was worried about. These old belts can get rather sticky and that can affect the speed with some wild fluctuations.
It was not the desk PSU I was thinking about. It was the internal circuitry of the turntable.
