G.Skill Sniper X for Ryzen
Solved by Streetguru,
Just now, Wyndmere said:I actually picked like the cheapest black PCB board because i don't really need any fancy feature. Now i kinda regret it because i would have gotten better compatibility with higher end boards.
X470 boards are coming soon with better memory support anyways. Not enough to be worth an upgrade though, you should be fine until Ryzen 3000
Color is not a good reason to buy a motherboard lol. The ASrock Pro 4 is usually the best budget AM4 board.
