I need more fan ports!
Go to solution Solved by mail929,
Just get a fan hub
Hi guys, i'm wanting to add 4 fans to my new case (which is the MasterBox Lite 5) but my Motherboard only supports 1 cpu fan and 1 case fan.  I would like to add more fan ports but i cant use a fan controller as the new case has no CD drive bays. Could some tell me how to do this?
Also i'm reading about my fans and what does it mean when it has "Connector: 3 Pin & 4 Pin Molex". Does this mean i can run this on molex instead?
Edited by TH Gamer
i'm looking at the SilverStone PWM Fan Hub (CPF04), i don't know if it is any good tho.
Quote
Exactly.
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
Get a four-way splitter cable from Phobya, costs 7$ on Amazon.
The silver stone hub cost the same in the uk and it does look nicer but thanks for all of your help. :)
