Hey guys im looking to get a pc i was going to buy one prebuilt but i got told that i wouldnt get as much performance as i would with just building one could you please list some parts that you recommend my budget is 700-800 max is 850 i want at least a gtx 1060 or higher and am looking for a i5 or i7
And how much would it cost me to take it to a shop to get it built because i dont know how to build it myself
https://linustechtips.com/topic/917703-building-a-pc/
-Moved to New Builds and Planning-
Welcome to the forums!
https://linustechtips.com/topic/917703-building-a-pc/#findComment-11252912
16 minutes ago, BrandonKHarris said:
well whats the best prebuilt one i can buy for 800$ USD
Whatever has at least an R5 1600 + 1060, better off building it yourself most of the time, it's not hard.
What kind of games are you going to be playing and what's your monitor's resolution/refresh rate?
US?
https://linustechtips.com/topic/917703-building-a-pc/#findComment-11252978
