Since this forum is about Builds ill tell you about mine
*Note all of this is also on my profile
  • CPU
    Amd Athlon x4 860k
  • Motherboard
    Gigabyte F2A68HM-HD2
  • RAM
    8GB DDR3
  • Case
    GTX 1050Ti zotac OC
  • Storage
    1TB WD BLUE
  • PSU
    EVGA 500w
  • Display(s)
    1 23.8" Dell monitor
  • Cooling
    Fan
  • Keyboard
    Tecknet
  • Mouse
    Tecknet
  • Sound
    Monitor speakers
  • Operating System
    Window 10 home
https://linustechtips.com/topic/917616-my-first-build/
Nononononono do not buy into this. Socket AM3 is dying and to be frank you've made terrible choices. What's your budget?
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
https://linustechtips.com/topic/917616-my-first-build/#findComment-11251776
I spent 1200$ to build an i3-8100 and 8GB of RAM, no GPU which I could have built for 350$. Just because.
CPU: Intel - Core i3-8100 3.6GHz Quad-Core Processor  ($119.79 @ OutletPC)
CPU Cooler: Corsair - H80i v2 70.7 CFM Liquid CPU Cooler  ($94.89 @ OutletPC)
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  ($5.40 @ OutletPC)
Motherboard: ASRock - Z370M-ITX/ac Mini ITX LGA1151 Motherboard  ($126.98 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($87.89 @ OutletPC)
Storage: Crucial - MX300 525GB M.2-2280 Solid State Drive  ($138.99 @ SuperBiiz)
Storage: Western Digital - Red 8TB 3.5" 5400RPM Internal Hard Drive  ($248.90 @ OutletPC)
Case: Phanteks - ENTHOO EVOLV SHIFT Mini ITX Tower Case  ($110.00)
Power Supply: Corsair - SF 600W 80+ Gold Certified Fully-Modular SFX Power Supply  ($114.68 @ OutletPC)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit  ($0.00)
Case Fan: Corsair - LL120RGB LED (Three Fans With Lighting Node PRO) 43.2 CFM  120mm Fans  ($119.44 @ Newegg)
Case Fan: Corsair - LL140 RGB LED (TwoFans With Lighting Node PRO) 51.5 CFM  140mm Fans  ($96.92 @ OutletPC)
Total: $1263.88
Generated by PCPartPicker 2018-04-17 16:18 EDT-0400
https://linustechtips.com/topic/917616-my-first-build/#findComment-11251794
Total: $1263.88
......... you went 5400rpm for a HDD? Are you insane?
https://linustechtips.com/topic/917616-my-first-build/#findComment-11251844
