i think its an rgb header or something, came with dark base 700
CPU: i7 4790k
GPU: Gigabyte Windforce3 GTX 1080
RAM: 8GB Corsair Vengance 1600MHz (@1333Mhz) + 8GB Balisticx Sport or something 1333MHz
MOBO: MSI Z97 Gaming 5
PSU: 1000W EVGA 1000G 80+ GOLD
Case: Dark Base 700
Cooling: Dark Rock Pro 3 CPU Cooler + Standard Case Fans
Drives: Intel SSD5 180GB (Boot Drive) + Seagate Baracuda 1TB HDD + Seagate Baracuda 4TB HDD
Keyboard: Razer Blackwidow RGB 2013
Mouse: Corsair Harpoon RGB
Speakers: Creative T15 Bluetooth Speakers
Microphone: Samson Meteor Mic
Monitor: AOC G2590VXQ 75Hz + ASUS VS247 + Shitty Generic 1080p 60Hz TV
LED Controller: NZXT HUE+
https://linustechtips.com/topic/917536-where-does-this-cable-go/
2 hours ago, stefanDB said:
that is indeed an RGB cable, and it should go on the RGB header on your motherboard, if it has one. The cable has a ground, green, red and blue cable as you can see on the side of it.
ive got a msi z97 gaming 5
dont think its got an rgb header
CPU: i7 4790k
Case: Dark Base 700
no its doesnt so you cant plug it in. you can get a controller box that is sata or moles powered.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
