I am looking for a female USB C to standard USB 3.0 motherboard header, but cannot find one. I have found something similar: https://www.amazon.com/Cablecc-Header-Type-C-Female-Extension/dp/B0755DDD9B but it isn’t the 3.0 header (I am using the H370N). Do they exist? What would this piece of tech be called? I’m googling random relevant words, so maybe that’s the issue
https://linustechtips.com/topic/917488-usb-c-front-panel/
If your asking what I think you are, no. USB Type C uses USB 3.1, not 3.0. You'd need a 3.1 header to use USB type C
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
https://linustechtips.com/topic/917488-usb-c-front-panel/#findComment-11250317
