Hi,
do you think that a ...
... will be ok in terms of cooling? I want the system to be near "dead silent", so only single fan will be running at about 300-400 rpm. My concerns are: is the "smaller" Macho (the big one does not fit in the chassis) good enough for passive cooling 35 watt CPU and is there a risk that the hot air will get stuck in the chassis with only one fan (the chassis has big openings at the front and back).
https://linustechtips.com/topic/917220-cooling-advice/
Should be, but more fans at lower speeds are quieter.  If you can add a few more, like 3 in the front at low speeds that would work better.
Also, if you can mount the chassis vertically so hot at flows up and out the top.  I do this on a 4U rack I have and it works well.
https://linustechtips.com/topic/917220-cooling-advice/#findComment-11247664
It should be fine.
https://linustechtips.com/topic/917220-cooling-advice/#findComment-11249079
