So i have a really bad PC (specs below) and i want to upgrade it so i can mainly play Fortnite.Right now i have the lowest possible graphic settings and i barely hit 30 fps and it drops every few seconds.I don't know if i should replace literally everything or just some parts.
Specs for my trash PC:
OS: Windows 7 Ultimate 64 bit
GPU: AMD Radeon R5 200 series
CPU: AMD APU A4-6300 3.70 GHz Dual Core
RAM: 4GB DDR3 1866 MHz
Motherboard: GA-F2A68HM-S1 which supports sockets FM2+/FM2
Power Supply: MS-500 (500W)
I was thinking of buying an RX 550 but then i have to buy a better CPU because then i will have a bottleneck but I don't know if there are any decent CPU's for FM2+ and FM2 sockets,and I'm really confused so that's why I'm asking for help.
please don't laugh at me and my trash PC... I'm aware that it's bad xD
https://linustechtips.com/topic/916847-pc-upgrading-help/
24 minutes ago, MarianKardelis said:
Alright,thanks guys for the help,i had a feeling that i would have to get a new PC so,cheers!
If your budget is tight, then look at first generation Ryzen 5 for deals. If you're in the US for example, right now you can pick up a motherboard and R 5 1600 for just over $200 total and that may well come down even more in price over the next couple of months.
https://linustechtips.com/topic/916847-pc-upgrading-help/#findComment-11244322
No use of upgrading in such an ancient platform..
I suggest u to get an old used optiplex with an i7 3rd or 4th gen fr about $200.....ND slap in a gt 1030.or some used GPU like GTX 770/780/780ti
I purchased a GTX 780 last week fr about $95
Or else save a little bit more....be build urself a decent gaming PC.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/916847-pc-upgrading-help/#findComment-11244389
