X370 Taichi LED problems
Go to solution Solved by aisle9,
33 minutes ago, jimkirk363 said:
Tried a bios upgrade and do u have u the latest version of the program for changing RGB?
Already on 4.60, I suppose I could try re-flashing it. The utility was downloaded straight from AsRock's site right before use.
Edit: Just heard back from AsRock support. Those guys are fast. I love it! Going to be that guy that marks it solved on my own post, just wasn't expecting to hear back so quickly.
So I downloaded AsRock's RGB LED utility last night to change the lighting on my chipset heatsink, something I've done many times. It started a firmware check, then the program crashed. The chipset heatsink LED went bright white and froze, and doesn't respond to the AsRock RGB program or changes in BIOS. It also doesn't turn off with the computer. It's just stuck as a static, solid, bright white. Anyone know of a fix?
Running Windows 10 on an R7 1700, Corsair RGB RAM (2x8GB), and an AsRock X370 Taichi, of course.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/916042-x370-taichi-led-problems/
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
  • 4 years later...
I am having exactly the same issue because I, too, downloaded and ran AsRock's RGB LED software. but sadly there's no mention of a solution in this post though its marked as solved.
Current Bios version is 7.30 and I tried everything but I can't get the chipset leds to turn off like I did when I first set up my system.
Any help would greatly be appreciated with the solution to this problem.
I dug through my old emails, and the solution was AsRock sending me new LED firmware to flash. After the new firmware was flashed, the problem was resolved. The link I was sent for the firmware has been dead for, oh, five-ish years now? AsRock probably still has the firmware and could send it to you if you get in touch with them.
First of all thank you for replaying and so quickly on a 5 year old post. So this is a problem which can't be fixed without contacting Asrock. Should I contact Asrock support or make a post about it on Asrock forums?
I'd open a ticket just in case they think something else is up and want to check that out before you flash firmware.
Well I wrote to asrock technical support via their website. they have sent me an automated email saying their technical staff will contact me soon. I will post here when they do hopefully, with a solution.
Update:
Finally got an email response from ASRock TSD today and the issue has now been resolved with a simple solution which is as follows since it might be useful for the same problem should somebody else faces it.
Copying it as it was received from ASRock TSD;
1.Completely uninstall RGB control utility, all remaining files need to be removed and reinstall the latest ASRock RGB LED.
Download link: https://download.asrock.com/Utility/RGB/RGBLED(v1.0.43).zip
2.Rewrite RGB firmware, you can follow the steps below.
Rewrite RGB firmware setup.
Step1. Run CMD as administrator
Step2. Input "cd C:\Program Files (x86)\ASRock Utility\ASRRGBLED\Bin"
Step3. Make sure ASRock RGB LED is closed.
Step4. Input "wICPFLASH.exe /file=nu51_1.10"
please mark this as a solution
