so my pc is now 3 months with a few bumps and today's problem is the mic idk y but when i plug in my mic on both places i can plug it in it won;'t pick up the mic what should i do
THINGS I HAVE DONE as "TROUBLESHOOTING"
plugged it directly to motherbnoard (won't work)
checked if mic was still working (still works)
if it has RGB (no)
does are the things i have done but to no avail
my headphones are the OG razer kraken pro
mobo gigabyte ga ab350 d3h
ASTRAY NOIR
CPU
Ryzen 5 3600
Cooler
Corsair H100I PRO
RAM
PNY XLR-8 EPIC-X DDR4-3200 CL16 32GB
GPU
ASUS ROG RTX 2070
STORAGE
SAMSUNG 850 EVO, 2xSEAGATE BARRACUDA PRO 1TB,A2000 1TB
Case
NZXT H500
PSU
Enermax Revolution DF 650W
MONITOR
MSI MAG272,LG 22MP68BQ,DELL D2015H
PERIPHIRALS
Ducky One 2 (HORIZON) || Glorious Model O- Pink || G305 || Razer Nari Essential || HyperX Cloud II
https://linustechtips.com/topic/915640-mic-wont-work/
2 minutes ago, Justin2Justin14 said:
ok have you reinstalled drivers?
yes
ASTRAY NOIR
CPU
Ryzen 5 3600
Cooler
Corsair H100I PRO
RAM
GPU
ASUS ROG RTX 2070
STORAGE
Case
NZXT H500
PSU
MONITOR
PERIPHIRALS
https://linustechtips.com/topic/915640-mic-wont-work/#findComment-11233337
Try plugging the headphones into the mic inputs and see if you get ANY signal. It depends on the speaker design, but in many cases this will work, as a speaker generally is a (dynamic) microphone wired backwards.
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
https://linustechtips.com/topic/915640-mic-wont-work/#findComment-11233360
OR if it's a combined mic/headpone plug (four poles, three plastic rings), plug it into your phone and call a friend. If the mic is dead it may be the wire or the mic itself that is dead.
https://linustechtips.com/topic/915640-mic-wont-work/#findComment-11233370
pretty sure it works tried with siri playing pubg and etc
ASTRAY NOIR
CPU
Ryzen 5 3600
Cooler
Corsair H100I PRO
RAM
GPU
ASUS ROG RTX 2070
STORAGE
Case
NZXT H500
PSU
MONITOR
PERIPHIRALS
https://linustechtips.com/topic/915640-mic-wont-work/#findComment-11233384
Does the motherboard support the 4-pole 3,5mm jacks? I don't think any of mine do.
If you have another set of 4-pole heahpones, like the ones that come with smart phones, do they work on your MB?
https://linustechtips.com/topic/915640-mic-wont-work/#findComment-11233404
still a no
ASTRAY NOIR
CPU
Ryzen 5 3600
Cooler
Corsair H100I PRO
RAM
GPU
ASUS ROG RTX 2070
STORAGE
Case
NZXT H500
PSU
MONITOR
PERIPHIRALS
https://linustechtips.com/topic/915640-mic-wont-work/#findComment-11233462
