I've been doing a lot of research and forming this build, I like it, but there's always room for improvement. I wanted a cheap (under $600) PC that could play triple A titles and maybe some streaming. I don't need anything crazy, just one that will run well and doesn't cost very much. I'm waiting for graphics card and RAM prices to drop before I build it, and I also want any suggestions I can get, so if you have them, please comment! Thanks :D
List: https://pcpartpicker.com/list/4tP3tg
I went with the Ryzen 3 1200 because it runs well for cheap, and I like AMD. I considered the 2200G and the 1300x, but in the end I think it has the best price to performance value, also I want to overclock, and with the 2200G, it has issues with the BIOS that I don't want to deal with.
I chose the ASRock AB350M Pro4 Motherboard because it has all the necessary slots, and can overclock.
I chose the Patriot Viper Elite because it works fine for a relatively cheap price.
I chose the SanDisk 240GB SSD because I wanted a good SSD that can load games and windows fast, I didn't include a hard drive because I really don't use much storage, I can always add a hard drive in the future if I need to.
I chose the MSI GTX 1050 Ti because it works great, although the price is very high, it will be worth it in the long run. I considered the 1050 and the RX 560, but in the end the 1050 Ti runs the best, and I think it's worth it, when the GPU prices drop again it will be even more worth it.
As for the case, I'm still deciding, I want one with a cool color theme (probably blue/green) but I went with the Cooler Master - MasterBox Q300L for now, it was suggested to me.
I chose the Corsair CX 450W 2017 PSU because it's very cheap, but has all that I need.
Once again, any comments or suggestions are highly appreciated, I plan to build this sometime in the next few months when GPU and RAM prices drop, but there's always room for improvement.
https://linustechtips.com/topic/915095-first-build-advice/
1 minute ago, Airdragonz said:
I might go with a Ryzen 2200g. Cpu performance is slight better than a 1200. And maybe hold off and save up for a better gpu down the line
The 2200G has a lot of issues with updating the BIOS that I really don't want to deal with, and I was considering a better GPU, but they're all so expensive I really don't know.
https://linustechtips.com/topic/915095-first-build-advice/#findComment-11228050
Just now, Litro said:
Yes I know they exist, I was considering buying one, but the Vega 11 (the built in GPU) on the 2400G is horrible
No it's not
The 1050ti gives you 5-10 percent more FPS and your getting DDR4-2400 which can lower FPS by 5-10 percent anyways
My life
https://linustechtips.com/topic/915095-first-build-advice/#findComment-11228055
8 minutes ago, Himommies said:
No it's not
I just feel like I will really regret it in the long run... I'm unsure, I'll consider it but there really aren't any Vega 11 vs. 1050 Ti benchmark comparisons to go off of. If you really think it will improve my build, then I guess I could. I'm just worried about regretting it.
https://linustechtips.com/topic/915095-first-build-advice/#findComment-11228087
Assuming you'll be playing at 1080p
Which you probaly will with a 1050ti
Then there's almost no diffrence
My life
https://linustechtips.com/topic/915095-first-build-advice/#findComment-11228091
Well I found this video, which is just a normal 1050 vs. a Vega 11. I don't want to sound like I'm arguing with you, I just really feel like it's not worth it. I would rather play it safe and spend a bit more to ensure that it will suit all my needs from now until I need to upgrade.
https://linustechtips.com/topic/915095-first-build-advice/#findComment-11228098
4 hours ago, Himommies said:
No it's not
the 2400G's iGPU is on par with a 1030 using a 3000-3200mhz kit, not exactly 5-10 percent less performance than the 1050ti.
https://linustechtips.com/topic/915095-first-build-advice/#findComment-11228889
