Help me complete my build.
Go to solution Solved by xven,
14 minutes ago, stateofpsychosis said:
Just plug all of that into pcpartpicker and go through them one by one.
Here, I did up your build in pcpartpicker and narrowed it down to boards that support overclocking (z370) since you have a K skew processor, boards that support SLI just to be absolutely sure you have an extra PCIe slot in case you want to get into VR and need more USB and because your system is high end enough that I'm assuming you want the option there..
If I were you I'd go with an Asus board,
More overclocking options than you know what to do with and the higher end ones have USB bios flashback so you basically can't brick your board updating the bios which is a really nice feature.
https://pcpartpicker.com/products/motherboard/#c=128&l=2&u=1&R=5,4
Thank you,
I am building a PC finally for myself after making dozen basic to go high-end builds for friends and family.
Looks like when you are choosing parts for yourself every decision is ten times harder...
So far i have a
Case : Fractal define r6 tg black
Ram : 16gb x2 trident z rgb
Storage : Samsung 960 pro 1tb
Gpu : Evga 1080 ti ftw 3
Psu : seasonic 1000w Psu
CPU : 8700k already delided
Will be using two 360 rads and a full custom loop, would like to go with a black and blue or black and purple build. My knowledge of motherboards is terrible but i would like something in the high-end with a darker color if possible black. I would like a motherboard with a possible full block since i do enjoy the esthetics of it.
While we are here...  Anyone knows a good person to reach for custom made Psu sleeves?
Thank you very much.
https://linustechtips.com/topic/915065-help-me-complete-my-build/
Cablemod.com or something
My main rig  Shardsedge
 ☟ INFO & SPECS
  • Information:
This build is made for video editing, Gaming and livestreaming.
probably 65% of this build has been bought used.
  • Specifications:
CPU  AMD Ryzen 7 1700
GPU  Sapphire RX 580 PULSE 4GB
SSD ✦ Toshiba TR200 240GB
HDD ✦ WD Black 160GB 2.5" + WD BLUE 1TB
PSU ✦ Corsair RM750X
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 3000Mhz
CASE ✦ Corsair Crystal 460X
MOBO MSI X370 SLI Plus
My old pc build  Smoke
 ☟ INFO & SPECS
  • Information:
This build was made for gaming especially, it was my second build.
i had some struggles livestreaming on it because the CPU just wasn't good enough for that.
(I do not have this build anymore)
  • Specifications:
CPU ✦ Intel i5 6500
GPU  Sapphire NITRO+ Radeon RX 470 4G D5
SSD ✦ Kingston SSDNow v300 120GB
HDD ✦ WD Blue 1TB
PSU ✦ Corsair CX450M
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 2400Mhz
CASE ✦ Sharkoon S25-V
MOBO ✦ MSI H110M ECO
So far i have a
Thank you,
