hello guys, i have Seasonic S12II Bronze 620w 80 plus psu, and i would like to know how many gtx 1050ti cards i can run on this psu (mining) with a system consists of pentium g4400 + 4gb ddr4 + b250-fintech mobo.
also could it handle for example the previously mentioned system + 2x gtx 1050ti (only pcie power required) + 1gtx 1060 3gb ? thanks.
P.S: i will oc the cards.
https://linustechtips.com/topic/914967-psu-required/
You should be underclocking the cards, not OCing them if you are mining. Most mining applications don't mind a low clock, and it will save you power and lifespan of the cards.
Considering the unit doesn't have OCP I wouldn't try it personally
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/914967-psu-required/#findComment-11226811
sadly mining on Zcash which requires higher core clocks and higher mem clocks to get higher hashrate.
in terms of the lifespan, i did a wide research about it, everyone said that as long as the temps are low, then there's 0 problem about the lifespan xD, i just wanna know how many cards would this psu handle, and i actually bought it as some miners recommended it and called it a great unit as long as its seasonic or EVGA
https://linustechtips.com/topic/914967-psu-required/#findComment-11226915
