What do you think about the laptop?
Some opinions about:
1. Price: is it worth >1400$
2. Build: Does metal make the chassy tougher than other ultrabooks?
3. Temperature: Is it too hot or just perfect for it purpose
4. Battery life: is it acctualy 7 hours of use?
I'm considering it to be my go to laptop. Please give your opinion whether should I buy it or another model.
https://linustechtips.com/topic/914926-razer-blade-stealth-2017/
Razer laptops aren't the best.. While I can't recommend another one, I would stay away from Razer
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
But im my country, pretty much no other models have the same specs, plus thin and light chassy as the blafe stealth
I'm in VietNam
Razer laptops have decent performance but they're a complete rip off in terms of money.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
2 minutes ago, datvu4202 said:
But they have a pretty damn good design and also able to stay thin and light
If there're no other options in your country, then go ahead and buy one.
Good hardware, nice design just pay a 20% premium (Atleast) for the name
See my Build here!
Intel 6700k -  Strix GTX 1080Ti - Corsair AX760 - Corsair Dominator 16GB 3000MHz - ASUS Maximus VIII Hero
Seagate Barracuda 1TB -  Samsung 120GB 840 - Samsung 840 EVO 250GB - Corsair H100i - Corsair Air 540 White -
Corsair AF120 - 2x Noctua NF-F12 - 3 x Noctua NF-S12
 Dell S2417DG - Dell UH2515H
No no. Quality issues, poor QC, poor customer support. AVOID Razer laptops.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
If I do end up buying it. Then it would be at a third party store like thinkpro.vn as I showed you in the last topic I posted ( If it were you). That way, they will be responsible for the issues that I have. Plus the closest competitor to it, the XPS 15 are like much more expensive than the stealth
People told you to stay sway from Razer laptops and you don't listen...fine, just get one, I won't even bother, the choice is yours.
Desktop specs:
