What Do I Do After POST
Solved by LogicalDrm,
I'm sorry but I really dont understand what ACHI or raid means, can you explain?
You shouldn't worry about this in new builds. New motherboards are set to ACHI by default. Just set boot order so that first is device with installation files (DVD or USB) and second is drive that you'll be installing OS to like SSD. You can remove other devices from that list as you won't be booting to them.
How do I know what frequency my ram is
Link to RAM you'll be buying? Most likely its 1600MHz and it'll run that as default. Setting XMP/frequency is not necessessary or even priority before OS installation. So boot order is only thing to worry.
