Fps problems
Solved by ToxicTexas,
1 minute ago, ToxicTexas said:I've came across this problem before and I believe it's something to do with Windows hybrid mode, try this and I hope it helps.
- Press the Windows key on your keyboard, type in Power Options, and then press Enter.
- From the left-hand menu, select Choose what the power buttons do.
- Under the Shutdown settings section, uncheck the box next to Turn on fast startup (recommended).
- Click the Save changes button.
There is a feature in both Windows 8 and Windows 10 that allows your computer to start more quickly. While these features (fast startup for Windows 10 and hybrid sleep in Windows 8) can be quite useful, they have been known to cause several issues, such as repeated restarts. There are two ways to turn these features off; to proceed, select either of the methods below and follow the steps.
Yes I took this from another website
hence the last part saying there is 2 methods.
