Hi guys ...!
This is really important and i think this is the right place to post it .
So i started streaming recently and my gameplay is somewhat different than non - stream gameplay
I play CS:GO so i can see the difference..
I have an OLD pc
I need a opinion will that PC be good for dedicated streaming
OLD PC -
i5 4440
16 GB ddr3
Gtx 960
CURRENT PC -
i7 8700k
16 GB ddr4
Gtx 1080ti
Also i heard about OBS NDi
Is that good or should i go for capture card
Also if you think this beast pc can handle encoding easily you are wrong im getting some trouble in gameplay
And you know if you lose specially in CS:GO people rage here .
Please help me out ..
Thank you
(Also i do ANIMATION and video editing stuff ,so please don’t yell at me for making this pc only for CS:GO)
https://linustechtips.com/topic/914465-important-dedicated-stream-pc-help/
1 hour ago, gharsh456 said:
Yea I noticed. Ty for figuring out .
btw any opinion on actual topic .?
The pc will do wonders, even too much for what you are wanting it for.
Unless you are a multi billion company, you shouldn't need a capture card.
hi.
4 hours ago, tj_420 said:
I am pretty sure the i5 uses ddr3 ram only.
That* i5. Not all of them.
If you are having issues with current system streaming just CSGO, chances are that there's some other issue. Those specs aren't it. CSGO is designed to run on lower end hardware to gain more players. And streaming (at entry level) isn't that demanding.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
I was mentioning the i5 he has, the 4400
hi.
