So after my AMP seemingly died last night, I am looking into getting a new one and really stepping up my audio setup
The budget is around $300 but possibly more.
My speakers are passive so they run off speaker wire so I need an audio setup that outputs with the wire.
The input is from my computer (if that wasn't already obvious)
EDIT: words
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
https://linustechtips.com/topic/91409-optimal-audio-setup-for-me/
Search Lepai on amazon - 20 bucks and you're golden if all you need is stereo.
The Lepai is what I have and it just died
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
Oh. I guess that means you're not interested in another...
Toping makes a few varies of amp/DAC/headphone amp combos. They're available on Amazon down here, but I haven't heard a ton about them that isn't in the reviews.
Using your full budget, and you're in AVR range, though low-range-ish AVRs.
What  about the AudioEngine N22 I'm likely going to upgrade to the P4B along with the new amp as well so I was thinking about getting both at the same time. Thoughts?
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
Their DACs/amps are overpriced in my opinion, but it's all designed to work and match with their products. Might as well get something you know will be good and at the same place. :)
