I just got a new monitor - Dell U2718Q which does 4K and supposedly HDR. I attempted to go into the NVIDIA control panel and change the settings to RGB/12bit/Full Range, however when I click apply the monitor goes black, then comes back and the options are back at the default values which are YCbCr422/10bit/Limited range. I am doing this over a known capable HDMI 2.2 cable. Also I have an Alienware 15 w/1070 that I am using as the system. Any ideas?
FYI: Cross posted in gpu section as well.
Alienware 15
-i7 7700hq
16gb
256 960 Evo
1tb HDD
GTX1070
https://linustechtips.com/topic/914083-dell-u2718q-settings-help/
UPDATE . . . I uninstalled the display drivers completely, and reinstalled them (391.35), still not able to get it to switch to RGB/12bit/Full Range. I have setup a post on Dell's forum and have yet to hear anything as well. Anyone run across this before?
Alienware 15
-i7 7700hq
16gb
256 960 Evo
1tb HDD
GTX1070
You're not going to be able to set 12 bpc RGB color at that resolution over HDMI. At 3840×2160 at 60 Hz RGB, the maximum color depth is 8 bpc. Anything else exceeds the bandwidth of HDMI 2.0. You need to use DisplayPort if you want to use 10 bpc color at the same time.
