Help!. Repaste Omen x 17
Solved by Neokolzia,
A Quick google will find guides from even HP how to disassemble the PC and repaste it.
You should make sure that it isn't just clogged heatsinks by blowing them out when its powered down with some compressed air
but here is a simple document here http://h22235.www2.hp.com/hpinfo/globalcitizenship/environment/productdata/Countries/_MultiCountry/disassembly_notebo_20171020223544623.pdf
And more documentation on HP's website. https://support.hp.com/ca-en/product/omen-x-by-hp-17-ap000-laptop-pc/16851401/document/c01657439
