I'm looking for a cheap-ish (maybe a few hundred dollars) FreeNAS Build.
Rules:
1. Parts must be from well-known sites (Amazon, etc...)
2. You must have a Case and PSU
3. The price of drives is not mandatory
4. Must use DDR3 or DDR4 RAM.
5. Must support a minimum of 5 drives
6. Must run FreeNAS
7. You do not need a screen.
8. If you want to include drives, you can include drives from 1-3TB.
Thanks for helping me out! :) (PCPartPicker Builds are Helpful ;) )
https://linustechtips.com/topic/913983-freenas-build-help/
1 minute ago, Electronics Wizardy said:
Budget?
Use case?
How much does power matter?
Does noise matter?
Id get a c2100 on ebay. 12 bay, cheap registered ddr3 and relativity low power.
2
I'll check out the ebay thing...
Budget: Somewhere in like $300 to 400-ish range (without monitor and potentially drives)
Case: I don't really mind, as long as it has enough drive bays
Power: Again, I don't really mind...
Noise: I don't care at all as long as it doesn't sound like a bloody plane is going over my house (it'll be sitting in a room in my basement, which is unfinished, so noise isn't really a problem.
https://linustechtips.com/topic/913983-freenas-build-help/#findComment-11217888
