I need Help
Go to solution Solved by An angry badger,
I defiantly think that build would do a decent job of playing those games. My only concern would be only have 8GB of RAM. I would consider buying the PC and then saving up for another 8GB of RAM. You would need to ensure the motherboard has a DIMM slot for another stick of RAM and that the RAM you buy is the same as the one that came with the PC.
Hey, Im currently saving up to get a Gaming Pc and i have been browsing pre builds, as for my first Pc i want it to be pre built, and i came across this machine, i play games mainly like Cs GO, League of Legends Overwatch and am looking to play some upcoming titles in the future like Far Cry 5 and the new call of duty games, im wondering if these specs will be able to handle playing these games while watching youtube and having other apps open like spotify and discord. Im not much of a tech guy so i need some help. Thank you for your help in advance
https://linustechtips.com/topic/913868-i-need-help/
Seems fine, though make sure the power supply is actually good. Many of these PCs go cheap on them (though you can, thankfully replace them easily).
Tier 3 or above is good. 450w ones will do for an 8500 with 1060 6gb
Desktop benching:
https://linustechtips.com/topic/913868-i-need-help/#findComment-11216803
https://linustechtips.com/topic/913868-i-need-help/#findComment-11216805
So would i have to buy another Adata 8GB DDR4 2400MHz Desktop Ram? and thank you
Hey i accidentally forgot to include the power supply but it is in the link there, just read a review on it, (https://www.techporn.ph/preview-thermaltake-smart-rgb-700w-psu/) and it says that it is a ok power supply so if i do get it there shouldnt be any problems right?
https://linustechtips.com/topic/913868-i-need-help/#findComment-11216937
when it comes to PSU reviews, the one you linked is fairly.. ugh, useless. This one for example, is what I call a detailed review.http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=516
You dont need that wattage anyway.
Desktop benching:
https://linustechtips.com/topic/913868-i-need-help/#findComment-11216991
ok thanks so i can just order that and then just install it later right
https://linustechtips.com/topic/913868-i-need-help/#findComment-11217015
